Hello there,
Not sure if people had this sort of issue before, I couldn't really find anything hence the reason of this post.
The machine has been off for a good 10 days, as I got the spindle refurbished, the spindle has been fitted back, everything fine for one day then problems.
It started yesterday throwing an alarm like 2025 tool magazine servo alarm, I check on the Fanuc servo amplifier and there was the letter C which means a cooling problem.
I managed to replace the fan and put everything back, now I have " only " 11 on the little Fanuc servo amplifier display which means something to do with the reference point of the ATC.
I tried procedures, parameters, everything I could, but the alarm won't go away, it seems to me that something is not releasing properly, I am not able to index the ATC in any other position, even in maintenance mode, and so on.
I am not sure if it's something simple or something major wrong with the ATC.
Batteries of the servo amplifier has been replaced 6 months ago.
Control is Fanuc 16i-m, the machine is Kitamura mycenter 1
Hopefully, somebody comes up with a suggestion
Thanks in advance
Thanks in advance
