I'm learning lathe programming and from what I can see most people seem to use rough turning (G71) instead of rough facing (G72) to rough out a part. I'd imagine that rough turning would increase time in the cut and minimize rapid moves, but at the same time it seems it would be less rigid, as you're machining away your support material at each pass. Rough facing would preserve the supporting material until the end, but it'd give your spindle a workout if using constant surface speed. Is there some reason why G72 isn't used to rough profiles?
