Areo Defense
- Apr 25, 2022
FNC 20, 74, 106, 1210? The 6 was decent control for the time, and if my memory serves me correctly, the no-frills 0 control shares a lot with the 6. If the turcite is in decent condition, these old box way machines could take some fairly heavy cuts. Is the head straight gear driven or have variable speed? The latter was fairly rare. I saw one, it was nice to have variable speed but could be wimpy when heavy drilling.Little progress. I was able to get the machine to run through MOST of my M57 Pot setting program. I cleared the CMOS and got through the entire program a couple times, then after that could only get through up to pot 11 for some reason before getting the same alarm as above. I am not aware of what that symbol is, and I have no errors on the diagnostic LED board on the electrical cabinet, no alarms on screen. Since I kept getting stuck at tool 11 I ended the program after 3 tools which left me with the ability to define that tool 2 was in the spindle, and 1 and 3 were in the carousel. After orienting the carousel and verifying that the "SPINDLE/POT" switch on the side of the control knew both tools were there I tried a tool change and it wanted to go but got stuck right before it grabbed both tools with the arm, with the same button lighting up on the control. Until find out what that is I fear I am dead in the water with tool changes.
I was able to start up, zero return, run the spindle, move the machine through handle, MDI, memory, I think the only thing I can't seem to get to function is the tool changer right now.
Can you tool change through all of the pots? I suppose if you cannot assign new numbers to all the pots, you could still use what's there. (assuming you don't want to throw a lot of money into this machine) Be careful when manually manipulating the arm and pots. I seem to recall the interlocks aren't in use when using the side panel to manually manipulate the arm/pots/clamps so it is possible to crash it.
As camhead said, Z floats quite a bit when tapping so make sure you use decent floating tap holders.
The axis uses actual OT switches and make sure you're at least 3" from axis home when zeroing. If you're too close to axis home, the axis will blow past the switches and will overtravel very HARD, risking ball screw nut damage.
In case you're not aware of this already, make sure you find all the grease fittings, I believe one is only visible with the table all the way to one side and don't skimp on the spindle oil spec.
The belleville spring stack on the drawbar rarely have issues but it's easy to fix. After removing the cylinder and a few things, the entire drawbar/belleville stack comes out as a cartridge.
I don't recall the controls losing the pot assignments after power cycling. Perhaps using origin after cycling??
Are you planning to program this machine offline?
