Besides the Keep Relays, I should also mention the DATA tables. You typically find both in the rear of the Electrical or Ladder Manuals. You'll know you're in the right place as there will be at the top of the page, a K or D followed by a number. The K's will tend to be low numbers whereas the D's will be higher numbers. Like in the 200's let's say. Then there will typically be 8 rows of Function Descriptions. One describing the machine response when the Bit is high (1) and another when the Bit is set low (0).
Note the exact layout will be Manufacturer dependent.
Tread carefully in these waters. If you don't understand completely what you're changing, just leave it alone. Also be sure to record your changes in the manual.
