Hello,
Self taught here and I'm not finding the solution in my manual or search.
I would like to know if its possible to set tool offset for a given tool by taking a cut and using a command in the tool offset pages similar to how I can set the work offset Z using the following command after jogging a given tool to where I want to place Z zero or Z whatever:
Work offset page:
M Z 0.0 - I use this to set zero to the face of a 2nd op part or set it .020" positive so I can face off some stock.
I would ideally like to be able to take a cut with a turning tool, measure it, then tell the controller the position of the tool tip and have it calculate the tool offset for me.
Thanks for the help!
-Jeff
PS the machine is a 2001 Hwacheon 2axis and the controller is a Fanuc 0T. I'm 99% sure it used to have a tool setter, I found what appeared to be parts of the tool setter in the chip pan when I bought the machine and cleaned it out. No tool setter now.
Work offset page:
-Jeff
