Dan from Oakland
- Sep 15, 2005
- Oakland, CA
If you are going to heat treat it after machining, i would suggest that you have it magnafluxed after heat treat to make sure there are no cracks.
Namibia has a big mining industry with the allied support although you would struggle to get them to do it for you.Somehow doubt that can be done in Namibia, def South Africa
Dye pen maybe
The V155 for this is the equivalent of Sanderson's MCV they don't machine well in the soft condition as they tear very easily. I used MCV/V155 to manufacture chuck spindles for tapping machines at GUD filters in Durban. Hardened and then turned with a Ceramic, I've got one in the Haas made it in 1992 and still growing strong despite all the abuse I gave it.I am thinking of using the V155 a stainless steel that is also used for knives. Does not need to be hardened. Wonder how difficult it is to machine with a small lathe.
I agree but have you seen where he is located. Gives new meaning to other side the black stump.Id think you could buy a Chinese knock off part cheaper than material cost
For answering questions, it's important to know that you are in Namibia.I live in Namibia looks like shipping cost is going to make it too expensive. Interesting though that it is still available in other countries.
Just use Nam' that's what we called it when I was based there in the military. Going home was referred to as catching a Flossie (C 130) back to the States.For answering questions, it's important to know that you are in Namibia.
I'd suggest updating your user profile here such that "Location: Namibia" displays under your disk icon on the left.
. In Australia the Hilux is known as the Rollux for a good reason.
Isn't "Nam" back then Vietnam?Just use Nam' that's what we called it when I was based there in the military. Going home was referred to as catching a Flossie (C 130) back to the States.![]()
No. First it was German South West Africa then just South West Africa the South West Africa/Namibia and after independence Namibia. Soldiers just shortened it to 'Nam. Probably had something to do with the Vietnam war also and movies etc.Isn't "Nam" back then Vietnam?
test wells are finding good prospects. Weird, I was looking at this the other day.Don't mean to hijack your thread, but I am for a moment.
In your country, Namibia, do they do any oil/gas well drilling?
Thanks for the info.Just spoke to my client. He said that they change the part on the different models so you can't use a later one. The later models have a taper with a nut holding the ball on. He thought it was a really bad idea to make your own ball, if you experience a sudden failure at 120 km/h you are going to do some serious damage. In Australia the Hilux is known as the Rollux for a good reason.The OEM parts are forged and heat treated as per my friend that worked with me at Bishop where we built tooling and machines for steering rack production. Personally I would modify the assembly to take a later ball and socket. I am not risk averse, I'm the guy that had a ball joint come apart on a Mini driving up Sani Pass which even the locals on donkeys fear. I stole some barbed wire off a farmers fence and wired it on and then drove through the night to where I could weld it as a temporary repair.
Butting a tapered bush into the hole where the old part was?
There a mechanic in Opuwa or even a scrap yard you could take your existing parts and do some comparison then get new ones when you get to Windhoek. I'll go past my customer on the way in to my workshop and check if he has parts I can give you numbers on.Thanks for the info.
Looks like on this part OEM is really worth it. My guess is no engineering shop will forge those balls.
So my conclusion is to use a part from a later model and do a modification would be a better solution.
Which part from a later model would work on a 1988 Hilux?
What modifications would it need?
Notice
