Houdini
- Nov 28, 2017
yep this is an old myth also that CPU frequency is exactly correlated to single thread processing speed, it isn't.The numbers in Ghz may be the same but the measured computing performance is a lot higher.
cycles/processes per second relative to megahertz/gigahertz.
as a side note, if you look at things more in depth anyway, without pushing the CPU into stability/reliability issues (the main reason for a "workstation")
they overclock numbers have definitely not been the same, they increased drastically.
Specs on i9 13900K
Total Cores
24
# of Performance-cores
8
# of Efficient-cores
16
Total Threads
32
Max Turbo Frequency
5.80 GHz
Intel® Thermal Velocity Boost Frequency
5.80 GHz
Intel® Turbo Boost Max Technology 3.0 Frequency ‡
5.70 GHz
Performance-core Max Turbo Frequency
5.40 GHz
Efficient-core Max Turbo Frequency
4.30 GHz
Performance-core Base Frequency
3.00 GHz
Efficient-core Base Frequency
2.20 GHz
