G'day
The Turret on my 2004 Mazak QTN 200 MS was not drilling cross holes (using live tools set for drilling on the OD) on center and after checking the x axis with a dial indicator it appears that the Turret needs to be rotated slightly to realign it. I removed the numbered plate and loosened all bolts in the ring of inner and outer allen head bolts in the attached photo (Red arrows indicate one hole in the inner and outer ring). I then removed two opposing stick tools and slipped a piece of 25 mm square bar into the positions where the stick tools were. The bar is about 4 meters long but I used the first meter (as I don't want to break anything just yet). The turret did not rotate so I thought better check I am not missing anything before I try harder. Does anyone know if there is anything else I need to loosen or remove before the turret will rotate so I can realign it? I am new to cnc machining so I may be missing the obvious. Any advice would be appreciated.
