lionelt
- Nov 25, 2010
- Oxfordshire
Sorry it's a long post.
The pinion on my Myford is badly worn, so bad it’s impossible to measure accurately
It has 16 teeth.
Gear is about .998” or 24.4mm diameter
Width of gear .515” or 13mm
Length of shaft including gear 3.900” or 99mm
Diameter .550” or 14mm
It meshes with the larger gear on the Rack Pinion Assembly.
I am told by Myford the gears have a pressure angle of 14.5°, and are normally 20DP.
The large gear on the Rack & Pinion Assembly appears to be 18DP As the O.D. for DP 18 is close to what the gear measures, 2.766” Diameter. At 20DP is come out at 2.500”
Never needed to make any gears in the past so used Google to try and understand how gears are measured, hopefully I have got this correct.
These are what I have found.
48 Teeth and 2.766” diameter
Measure across 5 teeth is 0.771”
Measure across 4 teeth is 0.610”
So is the pitch 0.161”?
For 18DP Gear I get these results.
PCD. Teeth Divided by DP = 2.666” For 20DP 2.400”
OD. Teeth +2 Divided by DP = 2.777” For 20 DP 2.500”
Module. 25.4 Divided by DP / 25.4 divided by 18 = 1.41 For 20DP 1.27
No of Teeth PCD x DP - 2.666” x DP18 = 47.98 For 20DP 48
This leads me to believe that the DP is 18.
Therefore I need to find a 16 tooth 18DP Spur Gear either on a shaft, or a gear that can be pinned to a new shaft.
I’ve looked at HPC Gears, they do pinion gears on shafts but not one long enough.
Emailed Myford and they do not have this part.
Contacted Lathe Parts but not yet had a reply.
Anyone able to suggest where I can obtain a suitable part or get one made?
Thanks
Photo 1
Shows the Pinion next to the gear it meshes with, I have used this gear for my calculations as it is a new gear.
Photo 2
Shows where the gear locates, it’s not pushed all the way in it sits under the larger gear at about 4 o’clock.
All the four gears at the top of the apron are new, unfortunately Myford no longer stock the pinion with the small gear.
Photo 3
Pinion is part number 45 in the diagram.
It has 16 teeth.
Thanks
Photo 1
Photo 2
Photo 3
