Fabracobbler
- Oct 28, 2020
Hi all, long time lurker but finally posting as I've got an issue I just can't get past.
I recently purchased a used Fanuc Robodrill a-T14iBL. This replaced an old Bridgeport clone CNC retrofit that I've been tinkering on for the last 10 years. I make parts in my garage as a past time and was ready to step up to an industrial grade machine. Finally have ATC, WooHoo! The Robodrill was optioned with a 4th axis and previous owner once had a rotary installed. It did not come with the 4th when I got it. The servo amp and wiring harness were also missing. The options parameters are turned on and the ladder has the relevant rungs for the clamp(brake) and index. I had a 4th on my old mill and can't imagine working without one now. So...
I purchased a used Kitagawa MR320. I know, big for the Robodrill but was too good a deal to pass up. I also purchased a servo amp, all interconnect cables and the 4th axis wiring harnesses (motor and encoder). I got these all installed easy enough. Double checked the wiring pinout diagramed in the manuals. Everything looked good. I then followed the "additional axis" install guide in the Robodrill manual. The exact motor in the Kitagawa wasn't a listed option as it is much newer than the Robodrill. I selected a similar sized motor and did the other required parameter mods listed in the manual then the obligatory power down. I am now getting alarm #'s 478 - A Axis illegal axis data(MNT) and 496 - A Axis illegal axis data(CNC). Manual says this is normal after modifying servo amplifier configuration and to set bit 4 of parameter 2212 to a 1 and then back to 0 and do a full power down reset. Well, I've done that, multiple times, and it just keeps coming back.
I've tried manually reviewing all the parameters set for the A-Axis but they all look reasonable. I've tried reordering the Z and A axis amps in parameters 1023, and 1910-14 and 1920-24. I've tried manually inputting the motor parameters for the actual motor in the Kitagawa (C8/2000i). I've tried selecting other stock motors in the Restoration->Add Axis Parameters menu. I'm at a loss! Always get this A-Axis illegal parameter alarm, sometimes many more alarms depending what I'm trying above.
I've shoehorned this mill into my garage for a past time so don't have the time/schedule or money to try factory service support. I've also heard nothing but nightmares with guys dealing with MMT here on the east coast. Looking for a little knowledgeable DIY advice to get this 4th axis up and running.
Relevant specs:
2001 Fanuc Robodrill a-T14iBL
2012 Kitagawa MR320 with C8/2000i motor (A06b-0226-B201) i1000 incremental encoder
Servo amp A06B-6096-H103, same 6096 series as the other 2 amps for X, Y & Z
Servo SW version 90A5/04
Relevant specs:
