As we grow out our fab shop, I am looking for economical pieces of equipment and set up. We live in the world of 4" and under square tubing that is currently cut on a nice but smaller semi-auto horizontal bandsaw. It does not have hydraulic assist on the cut so while it does not need to be manned at all times while cutting. I was looking into an auto-feed saw but they are pricey and the owner does not believe they will hold accuracy. We would be considered a job shop so generally we are cutting a wide variety of sizes/lengths.
What is the best road to go down for a saw under $10,000 that can cut fast up to 4"x4" x 3/8" walled tubing? Should I get a double post horizontal saw with a hydraulic or air cutting assist? Or one guy mentioned having good luck with using a vertical bandsaw that has a sliding head? We are seldom cutting really large material so the capacity is much less important than it having accuracy and good cut speed. Instead of getting a $65,000 saw with auto-feed, we are guying to hire a helper that will feed the saw as fast as possible and keep the cut list ready ahead of the fabricators.
Thoughts?
Thoughts?
