Steve's Machine&Fab shop
- Oct 26, 2023
- United States
I have Index 645 vertical mill I just got. It has a stuck R8 collet with a ER 32 collet holder in it for 20 plus years. I have tried using a 2 lb. brass hammer on the draw bar to try to break it loose with no luck. Also put some heat to it. I put a rubber cap on the end of the ER collet holder removed the draw bar and filled it up with pb blaster and let it sit for a week. I made a setup with 8" channel iron with 4 pieces of ½” 13 all thread in each corner. I tried to press on the draw bar (used ½” all thread for the draw bar) but the all thread tried to crumple in side of the spindle. My only last hope is to use a piece of 4140 bar with a ½” 13 threads on the end to screw in to the R8 collet. So far I have used 2 tons of force from a porta power. Any ideas or suggestions would be appreciated.
