Hi Everyone,
I am trying to turn a part in our KSI 38S swiss lathe, which is titanium Ti-6AI-4V grade Ø12mm bar. the finishing diameter is Ø4.45mm with step OD of Ø 11.5mm, and 160mm long. I used Walter DCMT11 R0.4 insert to cut the part in single pass by supporting with sub spindle. the cutting parameters were DOC- 7.5MM, SFM 200 and Feed is 0.05. I was able to finish the part, however, the part has runout/bend around 0.30 mm after machining.
is there any way to reduce the flex and decrease the cutting load?. The current load in Z axis varying around 50 to 60 percent.
The machine does not support Pinch turning, and also I cannot go multiple passes because the guide bush length is smaller than part length. so someone kindly advice regarding tooling or process.
someone told me to use 25*25 CCMT R0.2 tool/insert after milling it down to 16*16. But does C type inserts not flex the part more than D or V type inserts?.
Does anyone have experience with similar parts?
we have production requirements for 1000 pcs, any suggestions would be very helpful.
Thanks in advance.
Thanks in advance.
