Superbowl
- Feb 12, 2020
Thanks for the link Larry. I just bought that box tool on ebay. It seemed a better use of my time to modify it than to start from scratch and make something like the nifty custom tools others have posted photos of.I have used roller box tools on my turret lathes and they do a good job once you get the tool ground properly and get them adjusted to the desired diameter. The catch is that they are meant to be turret mounted and are normally used for relatively short work limited by the turret travel. For this job, you need to mount a big box tool with a 7/8" or larger hole through the shank to your top slide, probably with a custom adapter of some sort. The box tool has to be centered and parallel with the lathe spindle, of course.
I have box tools, but none with that big a hole in the shank. You will need at least a 1.25" shank and you will need to be sure the cutting diameter capacity will do your job.
This one might work, but the 1.5" shank is not drilled all the way through. Hole size not given, but it looks pretty big. Selling in a few hours, low bid at present.
https://www.ebay.com/itm/354884102347?hash=item52a0bda8cb:gRkAAOSwnbxknzdY&amdata=enc:AQAIAAAA0FxkWEdtEpGF0/CfCROOzKbQTpsYOzYWj4AZNN5EQglTXR5M+raubLtDINKSSHJgcA5TZ1GqjwEQW8eloOPq894K3k0z3x09hGBDw/I2zodC9UDO2EGeh38SPN0KdSRvzbsUAAraSPg++v+sJQ5EivANnCElfPILtk4BmG+Rw/kpDPUmdnJI02aLfDt2ouwaC8RG+oyfc937S+Lbv6qYPS/ScZEl3zpWvYaTpLlXfEyActT+ys/w9UMQtk99WLYtcJtDhvqPap/njlsbwBN7hYU=|tkp:Bk9SR-6MtJKmYg
You might find a shop that does custom centerless grinding and save a lot of aggravation.
Or get wheels with 7/8" bores.
Larry
Dave
