Thanks for these replies. i don't think any of them will get me what I want affordably in the quantities I'm thinking of (a few dozen to start--then maybe a few hundred). Didn't realize there could be warping issues as well. That would be very bad.
My idea is to make a custom or user-customizable miter bar for a table saw miter gauge product I'll be producing. The woodworking accessory industry offers a few "solutions" to the problem of table saw miter gauge grooves being inconsistent from saw to saw. Range is about .745" to .78". You really want a bar within .002" of optimal. Most use some sort of adjustable nylon inserts in one or both edges, or another expandable thingie of some sort. These aren't great solutions, as the nylon wears fast, and between the expanded areas you have a sloppy fit. Some designs even use spring loaded balls or Woodpecker makes a $70 miter bar with nylon leaf springs. That introduces friction, or if the friction is not extreme, slop....
My idea, since I'll be direct marketing one at a time, is to offer a custom width bar to within .002" accuracy. I start with undersized bar stock-5/8", and tape a piece of 5/32" thick plastic to one edge, and plane to width. It's a little hair-raising sending a steel bar through my thickness planer, but the plastic cuts like butter, and my nice helical carbide head leaves a perfect finish with thickness very consistant. But it's tricky getting a good glue bond to the plastic. Easy to get a good enough bond to plane, but I want the plastic to stay stuck long term.
Industry makes UHMW plastic wear strips (
http://crownplastics.com/products/durasurf-eta/) with the perfect transfer tape attached in perfect conditions meant for conveyers and other glue to steel applications. But they only go to .125" thick. Thus my question about 11/16" x 3/8" steel bar. Actually I'm getting decent results using good 3M transfer tape meant for "low energy" surfaces (plastic), wide belt sanding the UHMW with coarse grit immediately before gluing, but I'm sure the Durasurf stuff would be better.
Now I'm wondering if I might be best off taping a 1/16" shim piece to 5/8" width to create 11/16' and then the 1/8" durasurf-eta?
