1/4" Whiteside Hand Router Bits
Whiteside Router Bits 2004 1/4" SH x 1/2" R x 1-1/2" LD x 3/4" CL ROUND OVER$32 - 2 Available
Whiteside Router Bit 2003 1/4"Shank , 3/8" Radius , 5/8" CL Round over bit$25 - 11 Available
Whiteside Router Bit 2000C Round Over Bit Ball Bearing 1/8" Radius 3/4" Diameter$20 - 12 Available
Whiteside Router Bit 2001 1/4" Shank, 1/4"Radius, 1/2" CL Round over bit$22 - 13 Available
45° Chamfer Bit
1/4"SH, 45°, 5/8"CL$26 - 2 Available
Amana Bits
46153-K Solid Carbide CNC Spektra™ Extreme Tool Life Coated Spiral Phenolic, Resin and Composite with Chipbreaker 1/2 Dia x 1-1/4 x 1/2 Shank x 3-1/2 Inch Long Slow Helix Up-Cut Router Bit$120 - 7 Available
51428 Solid Carbide CNC Spiral 'O' Single Flute, Plastic Cutting 1/2 Dia x 1-5/8 x 1/2 Shank x 3-1/2 Inch Long Up-Cut Router Bit$105 - 4 Available
51446 Solid Carbide CNC Spiral 'O' Single Flute, Plastic Cutting 1/8 Dia x 3/4 x 1/4 Shank x 2-1/2 Inch Long Up-Cut Router Bit$36 - 3 Available
51442 Solid Carbide CNC Spiral 'O' Single Flute, Plastic Cutting 3/16 Dia x 7/8 x 1/4 Shank x 2-1/2 Inch Long Up-Cut Router Bit$40 - 2 Available
51421 Solid Carbide CNC Spiral 'O' Single Flute, Plastic Cutting 1/4 Dia x 3/4 x 1/4 Shank x 2-1/2 Inch Long Up-Cut$32 - 1 Available
51414 Solid Carbide CNC Spiral 'O' Single Flute, Plastic Cutting 3/8 Dia x 1-1/8 x 3/8 Shank x 3 Inch Long Up-Cut Router Bit$60 - 1 Available
46325 Solid Carbide Spiral Plunge 5/16 Dia x 1 Inch x 5/16 Shank Up-Cut$33 - 7 Available
46314 Solid Carbide Spiral Plunge 7/32 Dia x 1 Inch x 1/4 Shank Up-Cut$30 - 2 Available
46125 Solid Carbide Spiral Plunge 1/8 Dia x 13/16 x 1/4 Shank x 2-1/2 Inch Long Up-Cut Router Bit$30 - 2 Available
45728 Carbide Tipped V-Groove 90 Deg x 1-1/2 Dia x 1-1/4 Inch x 1/2 Shank$75 - 1 Available
Tungsten Carbide High Performance Mortise Compression Spiral with Chipbreaker$105 - 1 Available
45° Chamfer Bit
Amana Bits
