Not having done anything like before I could use some advice on making this part.
It is 8mm high.
I have a machine very similar to a Deckel FP1, would be practical to use the horizontal spindle with a copying device (which I don't have and should build first)?
Or on the vertical spindle, marking a thicker material, holding the bottom and then removing it ? The sides by the caliper anvils are somewhat regular arcs.
I can only use 1045 and then harden it, It's a clutch lever for an old lathe that I'm restoring.
It is 8mm high.
