Just FYI, any Brunner will be at least 40 years old now, since they went t/u in the early 80s. Good tough machines, but very old. A company called Atmosphair in Toronto advertises spare parts but I can't vouch for availability.
There are single cylinder 2 stage compressors, but they are rare, Puska (Spanish), Heywood (WWII aircraft vintage) and Holman "T" piston compressors. There is a large, flat piston crown riding on top of a much narrower piston body, much like a crosshead. The 1st stage air is compressed above the wide upper crown, and sent through an integrated intercooler, or even through a discharge valve in the piston crown, where it gets trapped underneath the crown in the annular compression cell created between the smaller diameter lower piston body and the wider upper cylinder. As the piston descends, the air is compressed and discharged out the side of the cylinder. Very compact, as you would want on an aircraft breathing air system. If you cut the piston in half vertically, it would resemble the letter "T".
