Read the following if interested in more details ...
Constant RPM vs. Constant Surface Speed (CSS)
It has been observed that the life of a cutting tool (insert) is maximum when the cutting speed is maintained in a narrow range for a particular combination of the workpiece material and the tool material. All tool manufacturers specify this range in their catalogues (in m/min and ft/min). Therefore, for a particular workpiece-tool combination, one has to select the RPM so as to ensure the desired cutting speed. Let
V = Cutting speed
ω = Angular velocity of the spindle
n = Angular frequency (Revolution per second) of spindle
N = RPM (Revolution per minute) of spindle
D = Turning diameter
Then,
V = ωD/2 = πnD = πND/60
If D is in mm then
V = πND/60 mm/sec = πND/1000 m/min = ND/318 m/min
If D is in inch then
V = πND/60 inch/sec = πND/12 ft/min = ND/3.8 ft/min
In practice, the rounded expressions ND/300 and ND/4 are used. Therefore, if D is in mm then the cutting speed is ND/300 m/min, and if D is in inch then the cutting speed is ND/4 ft/min. Thus, the desirable RPM can be calculated as
N = 300V/D where V is in m/min and D is in mm, or
N = 4V/D where V is in ft/min and D is in inch.
In a facing operation, in CSS mode, the required RPM to maintain the same cutting speed while machining at the center of the workpiece would be infinite (because D = 0). In such a case, the RPM increases up to the maximum possible RPM on a particular machine. It is also possible to restrict the maximum RPM to a lower value than what is available on the machine through a program code. This might be desirable for reducing the vibration caused by high spindle speeds.
A drawback of the CSS mode is that it causes excessive load on the spindle in the case of a large and sudden change in the radial position of the tool, as the spindle is subjected to high acceleration or deceleration. The worst of this situation arises when the tool is sent to its X-home position in a rapid move. This may cause damage to the spindle motor. Therefore, whenever there is a large and sudden change in the radial position of the tool, the CSS mode should be temporarily cancelled.
G97 selects constant RPM mode and G96 selects CSS mode. G50 restricts the maximum RPM. Except in a threading operation, where G97 must be used, G96 should be used in all turning operations.
