I think Im understand the software now. I need to put the SFM in the CSS and not an RPM.The G50 S550 forces the max RPM to 550 RPM. You say control is giving you 600 RPM at 1.512 dia. Are you sure it is not 550 RPM? That G50 line is important for safety so the machine doesn't max out rpm and throw stuff out of the chuck.
The next line,G96S1000, sets your CSS to 1000 surface feet/minute, way to fast. As programmed, anything under 6.945 diameter will run 550 RPM, since you've set the max allowable RPM at 550. Over 6.945 the RPM will slow to achieve a constant surface speed of 1000.
It's common to start the spindle in G97 at the RPM corresponding to the SFM and diameter at the start of the cut. Then invoke G96 for the cut. When the cut is finished G97 again at the RPM corresponding to the ending diameter of the cut. This way the spindle doesn't have to ramp up and down every time you go to your safe tool change position. That RPM value is figured with the formula:
RPM = 3.82*SFM/diameter
To find the 6.495 mentioned above rearrange the equation:
diameter = (3.82*SFM)/RPM
Thus
diameter = (3.82*1000)/550
diameter = 6.945
HUH?the machine doesnt seem to like CSS.
DMC DL30 Turning Center.HUH?
What machine?
I had a old rust bucket Studebaker Lark, You could get an amazing spark show by rubbing the concrete road divider at about 60 MPH at night. Good for about a 250' spark shower. Instantly removes tailgaters!Routinely see (even on this morning's commute) sparks coming from the road plow's skids.
Amazing how long the sparks stay glowing in the snow (Coolant) several feet behind the plow truck.
I found one a few years back, it was 2" thick steel, approx 6"wide and 24" long and had carbide brazed into 1/2" wide slots.
Numbers from my SFM formula ...
Yeah it always was. But for some reason the data I was input per the SFM formula would never give me the correct RPM at the control. So whatever data I get for SFM if I increase the value by 100RPM it nails the speeds at control side.Is spindle override at 100%?
Yep.So, the difference is of 100 rpm, irrespective of CSS value?
Details in post#15
Is it a mountain?
Circumference and CSS are not the same.
Notice
