Hello everybody,
I'm new here and my name is Bodo. I'm working as a fabricator and mostly do the machinig part in our shop.
We are producing conveyors and so most of my time I'm producing some Rollers with a lathe.
Since some months we have an older CNC Lathe. It's a NISSIN NSK40/150 with a Fanuc 6T Controller.
So far I got accustomed with the Lathe, read a lot here in this Forum, in Youtube several videos and I'm in the moment
making some shop tools and some small jobs for Orders.
But coming back to my reason I'm posting here my question.
The machine has 3 gears or gear ratios. The first is from 20 to 290 RPM, the second is from 290 to 900 and the highest is from 900 up to 2000 RPM.
They are switched with the commands M37, M38 and M39 and this works so far.
But when I use CSS or G96 the gears do not switch automatically.
So for example I need on the OD 800 RPM and while I face my workpiece at the inner end of the cut I need 1500 RPM.
This would involve to change the gear ratio from the middle range to the high range.
How are you handling these kind of speed adjustments?
I mean I could calculate up to which diameter I can go with the middle range, stop the cut, change the gear and cut to the end.
Is this the way to handle this or is there a better/easier way for this.
The original manual is not very helpful for this case and I haven't found any help in the internet so far.
It would be nice if somebody could give me some hint how they solve this.
Regards
Bodo
Regards
Bodo
