It has its place but I've had Haas DWO "easier and faster" bite me in the ass on more than one occasion.and yes i'm well aware of the fact that its a haas, still makes it easier and faster to program different things.
how so?It has its place but I've had Haas DWO "easier and faster" bite me in the ass on more than one occasion.
We've seen it enough times to know which parts can and can't go on the UMCs anymore, but there have been instances of those machines using DWO not being able to hold tight true position tolerances on complex parts. Yes, we limit repositioning as much as possible when we need to. Yes, we routinely recalibrate the DWO. Of course I'm sure any issues there are with repeatability drop by some exponential value when you're less an entire axis. Either way, yeah, I've had jobs programmed and done and almost running on a DWO machine where I had to go back and reprogram off of a tooling ball with separate hard pick-ups because the machine couldn't hack it.how so?
UMC is very different, i completely agree, they're total trash. on 4 axis stuff in VF series, DWO/TCPC works pretty well. the issues you're having are primarily due to shitty machine construction/geometry, and amplified by a control thats not capable of compensating for shit design.We've seen it enough times to know which parts can and can't go on the UMCs anymore, but there have been instances of those machines using DWO not being able to hold tight true position tolerances on complex parts. Yes, we limit repositioning as much as possible when we need to. Yes, we routinely recalibrate the DWO. Of course I'm sure any issues there are with repeatability drop by some exponential value when you're less an entire axis. Either way, yeah, I've had jobs programmed and done and almost running on a DWO machine where I had to go back and reprogram off of a tooling ball with separate hard pick-ups because the machine couldn't hack it.
We are a production shop that uses 4th axis alot. Currently using the 4th axis's programed as indexers with many many offsets.
Looking to upgrade our machines to have DWO to just make life alot easier for ourselves programming/ setup etc
What have peoples experience been with making the change over/ things to ask/ horror stories to avoid?
Programing side we use Fusion 360, which I do have some experience using in 5th Axis machines in other shops. Machines are 2018 VF4SS with HRT210 and 2021 VF2 with HRT210SS (with NGC of course)
I understand we need some settings enabled/ measured (MZRP I think Haas calls it).
Just looking for peoples experience with making the change over and how it went for them. There seems tobe a lot online with 5th axis with DWO but next to nothing with 4th axis.
this has nothing to do with right or wrong. neither way is 'right' or 'wrong'. if you dont have DWO/TCPC, you HAVE to model everything perfectly in CAD/CAM when programming, and it has to PERFECTLY represent whats actually in the machine. having DWO/TCPC lets you program any part without having to do any of that, just place your work offset anywhere on the stock you're machining. regardless of how you look at it, having it is much better than not. can you do without it? absolutely! but its akin to walking to work instead of driving your car. and yes i'm well aware of the fact that its a haas, still makes it easier and faster to program different things.
Thats fair enough.We've seen it enough times to know which parts can and can't go on the UMCs anymore, but there have been instances of those machines using DWO not being able to hold tight true position tolerances on complex parts. Yes, we limit repositioning as much as possible when we need to. Yes, we routinely recalibrate the DWO. Of course I'm sure any issues there are with repeatability drop by some exponential value when you're less an entire axis. Either way, yeah, I've had jobs programmed and done and almost running on a DWO machine where I had to go back and reprogram off of a tooling ball with separate hard pick-ups because the machine couldn't hack it.
well, i dont run hass crap, havent for a few years thank god! but yeah the machines i run all have TCPC albeit under different names, i wouldnt work any other way simply because its way more work than necessary.You hit the nail on the head there.
One of the main issues I left out is that the last guy I replaced for what ever reason didn't model things correctly. So to go back into every file for every product we have and remodel everything then reprogram off of center is a pretty huge task.
This seemed like the quickest and most reliable way forward for workflow and also backdating everything that has been programed before.
@empower did you make the change yourself? Or im guessing you already run a 5th Axis?
One of the other issues is that within Fusion 360 if you have more then say 3 or 4 setups with a bunch of tool paths it will reorder toolpaths in a super weird way. Often trying todo toolpaths before the required roughing toolpaths.Maybe more transparency needed from OP but he starts by saying he's in a production shop and is looking at jobs that maybe go from rapid prototype to long production or whatever.
I see absolutely no value in a quick and dirty setup if this is the case. If you're running a shitload of parts just make sure your setup is on center of rotation every time and program accordingly.
Plus we're talking about DWO on a Haas, which is reason enough for me to double-down on saying do it the right way the first time and be done with it.
huh? watchu talkin about willis? i've never seen it do anything like that.One of the other issues is that within Fusion 360 if you have more then say 3 or 4 setups with a bunch of tool paths it will reorder toolpaths in a super weird way. Often trying todo toolpaths before the required roughing toolpaths.
The programs workflow is really set up for using some kind of DWO for reordering toolpaths.
Well, no. If you have your fixturing modelled, as you should anyway, and know where the CoR is, as you have to in order to do dynamic offsets, programming off CoR saves you even having to probe the stock. CoR is faster and easier; just load the stock and go.i'm not denying that, lol. literally said that the purpose of it is so you dont HAVE to program off the center of rotation. well aware that you can do that, and i've done so many many times. but it can be a bit of a pain to always do that, sometimes you just need to throw something quick on a vise/fixture, probe it and go.
Can you pm me the macro your using?
I know that part, I guess I was just used to using a 3 jaw for 99% of my 4 axis work and a self centering vise for the other bits and locating them on center.
I wasn't thinking about using a platter that can hold multiple vises and whatnot where your part is out in space.
I can see that now.
Notice
