Laurentian
- Mar 2, 2008
- Canada
Hi there group, been reading and researching here for the past two months and have learnt quite a bit. What it boils down to is our Colchester Student 1800 has gotten beyond economical repair ( worn quick speed gear change mechanism and noisy headstock ) and is being replaced with a newer used Harrison UK built variable speed 13" lathe. We chose this model due to it's like small footprint and similar capacity as the square head Student. ( our shop is quite full and cannot free up anymore floor space while we're in here ) Plus there isn't much out there at the moment that fits the bill unless we import a new Asian lathe in what is an unpopular 13" x 25" size with powerful 3HP 3 phase motor. I would of been happy with an M300 gear head but none were to be had in Canada other than one that showed up on Kijiji partially disassembled. Was a basket case of mid seventies vintage with possibly just as much bed wear and other nasty surprises such as spindle bearings.
Harrison's sheet metal fabricated base is slightly lighter than the cast iron based Colchester headstock stand at 1450 pounds total compared to 1750 lbs. for the Colchester. Bed is an inch narrower on the VS330 and a couple other things seem a little smaller but for what we do the differences seem unimportant, both being D1-4 spindles so am confident the Harrison will be stout enough. Also thinking fact that it's variable speed it will see less gearbox abuse from staff between speed range shifts as a large knob is used in conjunction with a hand wheel for the mechanical variator, less prone to being slammed in and out of gear with the paddle levers which did in the Colchester over time.
Anyhow after much thought decided to send the bed out for regrind to a local Montreal based machine tool rebuild shop that does Pratt and Whitney work for the Longueuil engine plant. I had stripped the machine so far down that it would of been a shame not to rebuild it. So the bed is sitting here on the floor right now and will be skidded and shipped out this Tuesday. Machine is tail end mid nineties model run before they went over to the Alpha series and from what I could tell reading it's serial #'s and an electrical component date stamp inside the cabinet ( May 1995 ) It came out of the Air Canada Aveos Monteal plant when they closed up in 2012 where staff had obviously used it for sanding or machining some abrasive material as evidenced from the abrasive laden caked dried coolant and emery paper colored grit that was in every nook and cranny.
The bed will be re epoxied onto the base when it comes back, nice write up here in PM archives :
I'll post up a pic of the bed and saddle on the skid before they go out later this week.
Hugh
re-grouting lathe bed to factory steel cabinet base
Hello All My machine is an Harrison M300 (13 x 40) and I am setting it up in my garage. I have been having difficulty getting it level. It has leveling bolts in each of four corners. My level is a precision level with bubble gradations that are .0003" per foot. When I get the headstock end dead...
www.practicalmachinist.com
Hugh
