cuttergrinder
- Mar 16, 2007
- Salem,Ohio
Yesterday I was setting up to machine 2 internal keyways 180 degrees apart in a large roller of some kind. The bore is metric but around 11". I wish I would have taken a picture but the drawing was in German and it has symbols in the keyway tolerance that I am not familiar with. The keyway is 63mm wide and the part is about 22" long. The keyway had a tolerance of F7 which I understand but then it had a symbol that was 3 parallel lines with the center one being longer than the other two and then it said .025 and had the letter A. I assume this means it has to centered in the bore within .025 mm but thats only about .001" . I have to mill these keyways with a right angle head on a bullard boring mill. It cuts pretty well but holding the keyway to size and centered to the bore within .001" is going to be tough. Does anyone know what the 3 parrellel lines and the .025 A actually means?
