Antoine21130
- Oct 19, 2023
Hello everyone,
Recently got a Matsuura MC-660VG with a Yasnac J300M controller.
I have an issue with tool change process :
When setting the tool as an heavy tool, the tool change happen correctly but right at the end of process, the ATC arm doesn't return all the way to home (few millimiters away from SQ20 home limit switch).
Because of that, i get an ATC arm overtime error. When using manual recovery mode, the ATC arm goes to origin and trigger SQ20 perfectly so I'm not sure if it's related to the limit switch.
When setting the tool as a normal tool, the ATC start movement to grab tool from spindle but don't manage to lock it. It also trigger an overload error on the ATC motor driver and I have to reset it before using recovery mode.
So just to resume, in Heavy mode, everything goes well until the end ATC arm home positioning and in normal tool mode, the ATC arm doesn't even manage to grab the tool in the spindle.
Checked spindle orientation, Z0 ATC ready position, SQ20 and SQ22 limits seems to respond correctly in manual mode.
Thanks in advance for any help, really struggling on this one !
