Hi folks,
First post here, so an introduction to start;
Name is Dave, I Live in Kalamazoo, Mi and have not used a lathe in ten years since I was at engineering college in Manchester, England (emigrated to the best country in the world in 2004).
I have just purchased a lathe for home use on the many projects I've got going on. I've been searching for one just like this for some time - requirements were a 13" swing, not too long of a bed as everything I'll likelly be doing is within a foot of the chuck, oh and CHEAP!
So, I found a southbend over detroit way, nice 13" unit for $600. It needs a fair bit of work before using, but has the dual tumblers, taper attachment, and three and four jaw chucks. It was used in a high school, so has been abused somewhat in the past.
Obvious things wrong with it are as follows:
1) Carriage handwheel turns its gear behind the apron, which turns the next gear, which spins happily on the shaft. Seems like a dowel pin or key has come out?
2) Idler Gear wheel missing bushing and nut, other nuts missing
3) Reverse bracket handle and lock lever broken off / missing
4) Tailstock (was) really stiff and missing handwheel handle
5) Apron clutch handle missing (I actually have it - it is just loose in the bracket)
6) missing parts and brackets on the taper turning
7) Small amount of bed wear (not too concerned about given what I will be doing).
8) Small, but noticable amount of axial movement in headstock spindle (ball thrust bearing on gear end looks very dry)
So, here are some pictures - feel free to critique and comment on any of them as I'm running on empty when it comes to southbends and in fact any lathe that doesn't have metric threads
http://www.davecoxon.co.uk/lathe/01_main.JPG
http://www.davecoxon.co.uk/lathe/02_main.JPG
http://www.davecoxon.co.uk/lathe/03_bed.JPG
http://www.davecoxon.co.uk/lathe/04_tumb.JPG
http://www.davecoxon.co.uk/lathe/05_apron.JPG
http://www.davecoxon.co.uk/lathe/06_apron.JPG
http://www.davecoxon.co.uk/lathe/07_saddle.JPG
I don't think the bolt dropped loosely into to hole at the red circle is meant to be there? But what is?
http://www.davecoxon.co.uk/lathe/08_head.JPG
http://www.davecoxon.co.uk/lathe/09_head.JPG
Note the set screws are missing - this is a little concerning that someone might have been 'messing about'
http://www.davecoxon.co.uk/lathe/10_head.JPG
All seems well this end!
http://www.davecoxon.co.uk/lathe/11_gears.JPG
Lots of things wrong here!
http://www.davecoxon.co.uk/lathe/12_belt.JPG
Belt seems to be a polymer, rather than a leather belt. In good shape too.
http://www.davecoxon.co.uk/lathe/13_taper.JPG
Taper has a few pieces missing. Hand-nut at the yellow, and a bracket to secure the arm to the bed at the tailstock end I assume...
http://www.davecoxon.co.uk/lathe/14_adjust.JPG
It looks like someone has been in here before. There is around 140 degrees of TOTAL free-play at the cross-slide with the slide locked down, but the nuts just don't look right to me?
http://www.davecoxon.co.uk/lathe/15_tooling.JPG
http://www.davecoxon.co.uk/lathe/16_tooling.JPG
http://www.davecoxon.co.uk/lathe/17_essentials.JPG
Note the tumbler gate is not on the machine? WHY???
http://www.davecoxon.co.uk/lathe/18_unknown.JPG
Not sure what this is? It was in the 'box of bits'
http://www.davecoxon.co.uk/lathe/20_gauge.JPG
Micrometer gauge carriage stop I assume?
http://www.davecoxon.co.uk/lathe/21_missingbush.JPG
This bush and nut are missing and I've no idea what size, shape or material it's meant to be,
http://www.davecoxon.co.uk/lathe/22_date_maybe.JPG
Found this stamp - which suggests Nov 1966 - at least for when this housing was machined, or built up!
http://www.davecoxon.co.uk/lathe/23gears.JPG
Tumbler gears look well greased with sticky stuff, but no missing teeth
http://www.davecoxon.co.uk/lathe/24_unknown.JPG
http://www.davecoxon.co.uk/lathe/25_unknown.JPG
If someone can tell me what these are for I'd appreciate it. The clamp lines up on the cross-slide ways, and I guess is something to do with the taper turning?
http://www.davecoxon.co.uk/lathe/26_serial_no.JPG
Serial number. This dates the machine to 1967 from http://wswells.com/serial_number.html
What doesn't make sense is that the machine should have a 11/16" collet (according to the "T") but the diameter is 1.63" which makes it a 1 1/16" collet capacity - unless I'm misunderstanding something?
So, I'll be posting questions soon on how to get my lathe up and running.
I want to get the apron off first, to see what I'm up against, then get the drive gears fixed. A 'sympathetic' restoration will then take place; basically I don't intend on re-painting anything unless it really needs it - I just want to go through the whole machine and clean/lube it as needs be, replace what needs replacing, then put it to work!
The tailstock is already fixed - the alloy bushings that lock the sliding spindle were gummed up and not releasing. The OD of the spindle was also a bit beat up at the end. This is all rectified now and we're good in this area at least.
Sorry If you're on dial-up, but I have made the pictures as compact as possible for the detail I wanted to keep visible. I've not seen many folks post up this amount of photos in one hit, so you'll either find it interesting or frustrating - apologies if the latter!
Thanks for the intro, hopefully I can become a good addition to the group!
Dave C
Dave C
