I have one at home. It is a 12 station turret, A2-8 spindle nose, Y axis lathe. This is a true Y axis lathe, not a wedge type. The turret has its own axis that moves without a X move. They are stout box way machines with an intregal spindle. No belts.
I had a sensor go out for C axis position. Had to get Fanuc out to install and set up new sensor. Part was $7k plus labor. I had 2 techs tell me Fanuc had to do it.
Other than that issue it is a tank. Live tool is slow, I think 2000 max RPM. I have not figured out if it is even possible to turn a part with Y not at home. As far as I can tell it is not possible.
Control on mine is MF-6. I think It is a Fanuc 16T that Mori renamed. It is a standard Fanuc for sure, just cant remember exactly which one.
Mine is 1996 and you have to have a block for every tool holder you use. The turret does not have any wedge position for turn tools. They take a block that bolts on to turret with the wedge in the block. Every station can be used for a live tool. To activate Y axis you have to send machine to G30, which is as far away from chuck as possible. Also need to do that to turn off Y axis to be able to turn. Mine does not have much memory, but I don't use cam so I don't need a ton.
This is a true Mori and it is a tank that will hold size and finish as long it is not a turd. I am not sure that a 1992 is the same as mine, but this is my experience with mine.
