It's essentially a Schaublin 102 made by another maker. Spindle nose is the same, bed profile (tailstocks interchange), cross slide and any other accessory all the same. Quality is the same too. One difference is these have a bronze bearing at the front of the spindle with balls at the rear, where similar backgeared Schaublin will be roller bearings front balls rear. The bronze bearing arrangement is very well designed and easily adjusted though.
They did export some to the U.S. with 5C spindles, so check that. It may be a good thing, but if you get into Swiss stuff in the end it's probably better if it has the W20 spindle (more rarely they might be W25).
If you have a use for a 8" plain turning lathe, this is a great one. I part off 2" 316 in my 102 with no problem, then turn tiny little things to 0.005mm tolerance easily. A cross slide might run from 500 bucks and up depending on condition, tool post wise an AXA is a bit big, so you are looking at non-standard stuff there. W20 collets are plentiful and cheap used. Chucks with the right thread for the spindle nose come up regularly, backplates are rare to find. Proper chucks/backplates have a collar at the back that can be tightened to keep the chuck from flying off if you slam it in reverse- and it really works.
