jamesu229
- Feb 20, 2011
- Grant Alabama USA
I don't have enough coolant flow or fixture support for a drill I am using from Dormer, in al, now sandvik R587. Their starting feeds and speeds were mach f'ing booking and mach f'ing booking... I settled at 7000 and 120ipm. Which at a 10.3mm diameter ain't too shabby, less than half their recommended feed, but this is mostly due to the lack of support on the fixture. That being said, I find what they are doing in Iron to be a bit obsurd... ie .024 per tooth.. I don't see how a 6.something mm drill can handle that once it dulls up a little bit...
From the test results I heard of, it will, just not very long. The word is that its as good as any other 3 flute drill under "normal" conditions, but when pushed hard it had extreme margin wear and very short life. The video quality is bad, but look at the finish in the holes. It was impressive, but expensive. If I was to try one, it would be on performance po only.
