sheys
- Jul 13, 2006
- brooklyn, ny
Last week I stupidly did a bit of tune-up work on my old but adequate pallet jack. As long as i'd had it, the release handle had never been properly adjusted so I went ahead and set it properly. In the process I accidentally popped out the release plunger (for lack of a better name) and spilled a bunch of oil. No biggie, cleaned things up and put it back together, seemed to be fine. Today however, I went to pick up something heavy and no dice. Once more than a small amount of pressure is in the system the oil leaks right past the check valve. I took the valve assembly apart to inspect and clean and when back together things got even worse! Now I can't lift anything.
My main issue with this is that I'm moving my entire shop THIS THURSDAY. I need to get this fixed ASAP. There isn't much online about fixing pallet jacks, I'm hoping someone here can help.
The pics show the main check valve assembly out of the casting and the pump from both sides. Did I lose a part? Why is my check valve not sealing all of a sudden? I've had the thing apart and back together half a dozen times and the performance is always the same so I suspect dirt isn't the issue. It pumps up fine until there's load on it.
Next time I will leave well enough alone!
