dazz
- Aug 20, 2006
- New Zealand
Hi
I am doing deep maintenance on my Milling machine that is held together with lots of tapered pins.
Most of the tapered pins are in tight spaces where I can't get to the far side to backup with a heavy chunk of metal.
I read a post that included a comment from someone ( sorry, I don't remember the exact post or the person) about using a press type tool to remove taper pins.
Taking that comment, I designed and made a tool to remove taper pins on my milling machine. The tool is sized for my mill.
The screw is an M6.
I designed two versions. One is made of steel thick enough to drill and tap (one piece)
The other version for tight spots is made of thinner steel with a threaded bush welded on.
The screws are turned for different sized pins.
If a pin protrudes from the fat end, use washers to create a space to release into.
The screw is an M6.
