jeff46
- Aug 20, 2010
- UK Cheshire
Hi Guys,
I own an old colchester student lathe, the bull-nose type, it works well however When turning a parallel piece I am getting faint lines in the surface finish approx 6mm apart along the full length of the piece, it's almost as though the traverse is stalling or something every so many revs where it leaves a visible line on the work.
Incidentally the cutting tool is positioned at the rear of the work therefore the work turns clockwise and the cut is taken from the back not the front as in conventional set-up, the traverse direction is from tail-stock to chuck.
I can't actually see any jump or slowing of the saddle but the marks on the work indicate something is wrong???, everything seems oiled and free moving so I'm at a loss as to what may be causing this.
Not sure how to check the thread piece that links to the feed bar when you engage the traverse or if there is any adjustment in these things.
Help please, any suggestion welcome.
Jeff
Jeff
