lin842
- Sep 27, 2008
- Richmond Va
I bought a new, old Bridgeport mill several months ago and haven't had time to play with it much. I had a little job a guy wanted me to do so I figured that would be a good time to try it out. In my old shop that burned down I had an older Bridgeport that was totally manual, so I'm not well versed on this fancy stuff that's on this mill. My brain hurts trying to figure out this Newall DP 700 DRO but that's something for another day.
I got my boring bar out along with a collet. When I tried to tighten up the draw bar nothing happened. I have the regulator set at 100 psi with good clean air and all that happened was I could see the unit move just a little bit like it was in a bind or something. I took the cover off so I could see what was going on and everything looked ok but would not move. I decided to tap on the side of the air motor to see if that would help get it going and when I did it would then turn enough to force the motor down against the spring but not enough to turn the draw bar. A little more tapping and I finally got it to turn but it was really slow. I did manage to get the collet tight, but it would not loosen it back up. I let it sit for a while and went in to get on the net to see if I could find anything that would help me figure out what is wrong but found nothing that was helpful. Now the thing won't move at all, when I push the buttons, I get just a little puff of air out of the vent tube.
I don't know how long this machine sit before I got it but I'm thinking that the motor is gummed up and is why it won't turn but don't want to mess anything up when trying to get it free so I figured it would be best to ask here from people that actually knows what might be going on and how to fix it. You guys have helped me several time before with problems I've had before and hopefully you would be kind enough to help out again. Thanks.........
