Hi all !
Got an "interresting" problem happening yesterday. Parts were running fine, and then the OD was .25mm lower !
Roughing was not broken so no finishing tool digging due to too much stock left. Finisher also not broken...
I'm using a VBMT insert with .4mm nose radius for finishing, 200m/min in xc38 Steel (1035 Google says !), taking .5mm radial DOC at .15mm feed. It is a screw on holder, almost new (not crashed!).
Re-probed the tool after, tool offset moved quite significantly. My boss says it il the insert that moved in its seat because too much DOC? I used to take the same DOC in 316 SS at my old job, never had a problem but with the better held VNMG. He says .25mm DOC max for finishing. Tanks! I think its more the .2mm left on the faces of the shoulder that made it moved... I used to left only .1mm in SS...
What do you think guys?
Thanks!
Thanks!
