Yes, i have a brochure in which the DECKEL S500
machining center is described.
It is a brochure about all DECKEL milling and drilling machines.
Unfortunately only in German, but you can assign the technical data so well.
Translation:
Range of movement of the tool, mm: X (longitudinal) 1600, Y (vertical) 800, Z (transverse) 800.
Table, clamping surface 2000x 1000mm, drive power work spindle 18kW, speed range 63-3550 rpm, feeds dependent on control, programmable up to 4000mm/min, rapid traverse 10m/min.
Distance measurement direct, T EU according to VDI 3254: X ,Y 0.015mm, in Z 0.02mm.
Automatic tool changer from moving disk magazine.
NC path control for 3-5 axes.
Expansion stages variants:
X =2000 or 2400mm
(in addition,Table length 2400 or 2800mm), Y=1000mm, spindle power 24kW, speed range 20-2800 rpm,
1 NC rotary table or 2 rotary indexing tables, chip conveyor, CNC path control
