jccaclimber
- Nov 22, 2015
- San Francisco
I have Sharp HLV-H clone. I understand how to thread to a stop, but want to bore to a stop using the carriage power feed. Currently I get it close on the power feed and then walk it in by hand on the DRO, which results in either telling me how much I overshot, or getting to the right place but with a very different feed rate than the rest of the bore.
On a Colchester I used to use there was a clutch on the carriage drive rod and a bolt on micrometer carriage stop. However, it was explained to me that the clutch was there for emergencies only, and using it would eventually result in breaking the shear pin on a good day or a gear tooth in a bad one.
On an HLV-H there are clutches on the power feeds. Are these designed so that I can mount a rigid stop and disengage after running into it, or is that inadvisable?
If it is inadvisable I can always wire a relay into the feed motor so that it stops the feed motor when I hit a switch.
