M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
I've got an old Band Saw that I want to fix up and while I'm at it, add some function too. One feature I want to add is hydraulic down feed assist (currently has a big adjustable coil spring), and I'm thinking it would be handy to add a lift function to it too. Obviously I'll need more than the typical closed loop control that bleeds from one side of the cylinder to the other, so I'm thinking a pressurized system with a directional control and two metering valves. Then I can set an adjustable slow down feed, and a faster return feed. I have actuators, pumps, valves, etc. already, so cost of the update isn't an issue to me. Just looking to add some practical function utilizing stuff off the shelf. I plan to leave the current coil spring set-up in place so the hydraulic lift isn't doing all the work.
I first considering doing this with pneumatics, but I've read that they perform poorly in an application like this, so I'd need to add a hydraulic pump. My first question though, why can't I use the cutting fluid and it's pump to also power the hydraulics? Assuming I keep the fluid quality up, the reservoir full, and add/maintain a filter to keep swarf out of the valves, how much trouble am I getting into? I'd like top run water soluble fluids, but the saw is old enough to have run cutting oil originally, so I could stick with that. I'm thinking going slightly bigger on everything would help too, like 3/8 to 1/2 NPT parts instead of 1/4" to limit the chance of a foreign particle causing issues. The coolant pump I'm using is an old Brown & Sharpe #1 gear pump, which can run 300 to 900 RPM producing 1 1/2 to 4 1/2 GPM. I have an extra pump that I can use to run the cutting fluid and hydraulics separately, I'm just wondering if combining them is at all feasible.
