MachineAmateur
- Jan 11, 2021
Hello,
Now i've been trying to find any guides with varying situations, but nothing so far, everything describes the tool nose 3 with run of the mill profile turning. I also suspect that the crappy lathe i am using does not properly compute certain situations and might be the culprit here, but i want to first make sure i am doing it right. The manual is awfully short on this issue and has incorrect descriptions too.
- Lathe has turret between operator and stock.
- Only one tool datumn is available (cannot use left and right offsets for same tool), this might be the reason why i will fail at this task no matter what
- Radius from right to left works with G42 properly, nose setting 3, no issues there
- I have tried nose 3 and 8 and there seems to be no difference in the behaviour. Is it correct to think that nose profile 8 is used to create left and right corners by switching G41<>G42 or is it only used to compute the Z variation between them (essentially any nose setting would behave as rounded insert)?
What i am attempting to accomplish is to use a grooving insert (1mm radius so basically round nose) which would profile a small stud that has one reverse radius at the chuck end (right before the parting). This makes it impossible to use the typical right-to-left profiling run as i have to switch something in between to get the reverse edge. Another thing is that i am attempting to learn this thing properly and use the flimsy grooving tool as intended, so i would rather push into the stock than sidestep into it as the tool visibly bends from the forces when doing so. So reversals will happen.
Here is a simple example code for testing which makes the routine do some crazy stuff (it might plunge straight in or attempt to create full circle etc.), i've attempted to use both commands. Note that this is not the actual profile, just for testing with the end of stock for less material waste.
If i generate the same code, where instead plunging i come from right to left at X14 Z0 with G42 it works properly.
Code:
T2.2
G0 X18 Z-5
G1 X16 ;Stock at 16mm
G1 G41 X16 Z-2 ;Lead into the tool nose compensation, left to right
G3 U-4 W2 R2 ;Counter clockwise arc ending at Z0, edit: W-2 changed to W2
G0 X18
