angelw
- Sep 10, 2010
- Victoria Australia
For each diameter the surface speed is calculated on, it's the same circumference on either side of Zero, therefore, it's not a case of the speed going down and down, then up and up. For the surface speed to be zero, the diameter must be zero and therefore, it doesn't existIn reality, the surface speed relative to a point gets lower and lower and lower then goes up and up and up ... in between going slower and slower then higher and higher there must be a point where it is zero.
