Nerdlinger
- Aug 10, 2013
- Chicago, IL
Hi Everyone!
I have a few questions about cutter comp I am hoping y'all could help with (especially #3):
1) It is my understanding that when invoking cutter comp on a mill, the G41/G42 line must include either a G00 or G01 move of at least the radius of the tool in either, X, Y, or X AND Y. Is that correct?
2) It is my understanding that whilst in G41/G42 on a mill you either 2.1) can not or 2.2) should not make Z moves. Are either of those correct?
3) How the heckarooney do you properly invoke cutter comp on a lathe for a standard turning op? I have been successfully getting away with it but don't actually know what I am doing! I have read the FANUC section on it and I THINK it sounds like you are supposed to make an X move on the G41/G42 line at a Z location somewhere "upstream" of where you will be cutting and from there it will move such that 2) the tool nose center will be lined up in Z to the programmed location of the very next block...the block right after the startup block. If that is correct then going to Z0. on the block right after the startup block would gouge into the face by the radius of the insert...is my understanding correct? Any insight on this topic would be appreciated!
Thank you!
Thank you!
