Harry,
I take off my hat and you are a wild animal!!!
I think this procedure is a treat here in the forum and i gave a lot of likes.
That the move of the DECKEL resulted in the relocation of oil is a very interesting point.
TOP and keep on going.
Cheers
Perhaps that is the reason why Mikron owners manual says that machines are delivered with no oil in Y axis and that it should be filled to level prior putting into service... I don't recall anything in the manual telling the oil should be drained before moving, but it does seem to make sense now
though there is a path for it to drain to the bottom of the machine from there (at least on Mikrons it is), horizontal spindle hydraulic drawbar cylinder failed on my machine for some reason (haven't used horizontal spindle for a year prior to this, and haven't taken it apart yet, just disconnected and plugged the supply line), and the hydraulic pump emptied the tank into that cavity which then drained to the bottom of the machine where the run off way oil is gathered
