Popping out for a moment...
We bought one of these two years ago(received & put in operation June of 2018).
Ours is run with the fancy top shroud removed.
There have been a few issues:
- The oil level sight window, being a thermoplastic, allowing oil to spew out once things get hot; I'm rather certain they removed it from future models, seeing as how they told us we must remove ours(I actually liked it, after tightening it down better).
- Just a couple months ago the pressure switch froze up on one of the contact-points and the unit wouldn't run -- fortunately the switch has 3 terminals with only 2 in use(240V); found the dead contact(no continuity when the pressure switch is engaged), and swapped its wires to the unused set of contacts.
Upon seeing that it can toast a pressure switch in only a couple of years, I went ahead and purchased a 40A contactor(that outta do it) and ran the pressure switch power output to the contactor coil, and now I don't need to buy replacement pressure switches
We're a machine shop with 2 Haas mills going on an average day; we plumbed the Eastwood unit into the backup 80 gallon Husky so we have more draw-down capacity; even then the Scroll compressor can kick on once every 5 minutes(if we're blowing-off & changing-out parts often), and it does a good job keeping up with our limited demands(no blast cabinet in operation here).
Overall it has been a positive experience for this family operation(4 of us here).
Being a salvage & make-do kind of guy, I heard where someone experienced one of their motor capacitors exploding after some years of use... so I have ordered my own replacements(a start capacitor, and a run capacitor) in the event that ever comes about.
