Vanillamachinist
- May 10, 2021
Hi there,
I recently bought this Cardiff 17 inch swing lathe, there should be some pictures below
Does anybody out there have a similar lathe? info is quite scarce, vintage machinery.org and Lathes.co.uk do have some info that led to me believe it is close to a "senior" model but, there are a few differences between their examples and my machine.
I am looking for any sort of workshop technical manuals that might be out there, also I need to reproduce the speed and feeds chart on the lathe as a previous owner had removed it for some reason.
The only problem with the lathe is that centre bearing is tight, and continues to get tighter the longer you run it,
Thanks in advance to anybody selflessly taking some time out of there day to reply, much appreciated
Many thanks and kind regards
Shaun
Shaun
