There aren’t any, people just like to complain about things they don’t understand. The software itself is more than adequate for most parts that run through most shops. ITAR Compliance is its main drawback and the reason it’s not in more shops.What are some some genuine drawbacks to Fusion 360 CAM for 2.5 and 3 axis milling?
Seems like the main criticism of the software is that it is associated with the home shop and maker crowds, and that it is sold by autodesk.
I hate subscription also, but can that even be considered a drawback for Fusion when most other CAM softwares make you pay thousands in "maintenance" fees every year. At least with Fusion, the software is in active development.
But I'm genuinely curious to hear what people dislike about Fusion CAM.
The active development and the way they don't release a stable version with an option to test the Beta is a drawback. A tool path that worked previously can stop working altogether or do something unexpected all of a sudden with an upgrade.At least with Fusion, the software is in active development.
^^^^This. I started with Smartcam in the 80s. Went to Edgecam when smartcam died. A couple years ago I switched to Fusion when the $2K /year maintenance of Edgecam and indifferent support became offensive. For normal 3-4 axis work milling, what i get with Fusion is better than what I had with Edgecam in several ways. and I have 3d capability, adaptive etc.for way less than I was paying Edgecam for 2-1/2D. I have a complaint about fusion turning about adding rapid points but you didn't ask about turning. I'm hoping it gets added soon.There aren’t any, people just like to complain about things they don’t understand. The software itself is more than adequate for most parts that run through most shops. ITAR Compliance is its main drawback and the reason it’s not in more shops.
^^^^^Also this. My biggest complaint.The active development and the way they don't release a stable version with an option to test the Beta is a drawback. A tool path that worked previously can stop working altogether or do something unexpected all of a sudden with an upgrade.
This has been my biggest (legitimate) complaint about Fusion as well.The active development and the way they don't release a stable version with an option to test the Beta is a drawback. A tool path that worked previously can stop working altogether or do something unexpected all of a sudden with an upgrade.
I think I understand it fine. But Wildfire is so much more capable and also nicer to use and also doesn't involve the scum of the universe, autodicks. Altho it does involve second-level scum, ptc ...There aren’t any, people just like to complain about things they don’t understand.
You should train Autodesk how to use their software. I have spent hours, literally hours, in meetings with their "experts" who cannot get a model to change without wiping out all the tool paths. They cannot get models to update correctly when derived. They cannot get the drawings to not explode when any change is made. I have one set of models I made at the direction of one of their experts, it is so convoluted and F'd up, that you cannot make ANY changes, otherwise it wipes out all of the programming. Remodeling and reprogramming would take.... days?I have been using Fusion since before you could pay for it and was on the CAM beta team before it was released. How much I liked it was closely related to how familiar I was with it. Many of the issues I had with it were from not knowing how it was supposed to be used and in the end I couldn't blame the software, just my ignorance. Sure the software was lacking sometimes but most of the time it was me. I have had it do buggy things but they have been rare occurrences. One rule of thumb I learned the hard way, twice, is do not have work in progress when you update it! Save your work, close it, and then update. Now that you can put off updates it is a non-issue. Custom threads are easy if you don't model them. Model the id and set the pitch when you create the tool path. It is sensitive to how you create your CAD models but once you learn how it likes to be done you should be fine. I use the history feature and respect it when making changes, you can't just do them willy nilly. I do have some old models that are buggy but they were all made before I learned how to use the software, but they are not buggy enough to make me redo them. I haven't worked with someone else's model so I have no idea of problems with working on imported models. If you stay inside the Fusion ecosystem and leverage the integrated CAD and CAM it is quite powerful. Things like making a family of parts that have small changes between them can have big time savings. If you did your model correctly you can make the change to the model and all of the toolpaths will update automatically. New parts can take all of 2 minutes to make the changes and post the new programs. This tight integration between the CAD and CAM software is something I consider a must have, for my needs. All in all I don't have any important issues with it and do think it is by far the best bang for your buck.
It is interesting how different our experiences are. One of my workflows is to model the parts in separate files, insert derive them into an assembly file, insert derive that into another file to create the CAM paths from. The CAM file may also have a fixture inserted into it, that has clamps and stops insert derived into it before inserting the fixture file into the CAM file. And still no issues, other than trying to figure out where to modify parts and then get everything updated so the CAM file is up to date. That is a worst case scenario but I have a few CAM files like this and still make changes and post code fine. I often insert derive a model into a file to do the CAM so I don't get the model file too cluttered up. Most of the components in my computer are now 14 years old using an AMD Phenom II X4 CPU so this is all on old hardware.You should train Autodesk how to use their software. I have spent hours, literally hours, in meetings with their "experts" who cannot get a model to change without wiping out all the tool paths. They cannot get models to update correctly when derived. They cannot get the drawings to not explode when any change is made. I have one set of models I made at the direction of one of their experts, it is so convoluted and F'd up, that you cannot make ANY changes, otherwise it wipes out all of the programming. Remodeling and reprogramming would take.... days?
When I say custom threads, I don't mean an odd pitch, or a different diameter, I mean... custom. Well, most are standards, but industry specific standards. The threads themselves are often machined, not with a thread tool. Think thread blocks for blow molds and the like. And they are timed, to a datum. Some parts are timed to a mating part, which has to be timed to a cam, which has to be timed to an internal datum. It sure would be swell if it could be modeled so that you know everything is timed correctly.
Importing models are even worse. Good lord. I have a customer that sends step and dxf files and they are never right. Fusion will take one dxf file with a contained sketch and blow it apart into multiple un associated sketches.
I had one meeting with some lady who claimed to be somebody in the US, and some guy in the UK who was their top CAM guy. He couldn't get the tool paths to work, but showed that on his machine they worked perfectly. He said it was my model that was the issue. I modeled the part wrong. So he showed me how to model it. And the tool paths didn't work. I wish I could have recorded that session when he said, and I quote, "What the fuck!".
That sums up Fusion pretty well to me.
That all works perfect in Pro/E (wildfire, don't know about "creo"). Pro/E has its own peculiarities and annoyances but it does work, the way it's supposed to. And it's plenty plenty capable.Do I have tons to learn, 100% you bet. Fusion claims that you can model where making a change will alter everything down stream. I've never been able to figure that one out. I'll own it. I'm sure it works somewhere, somehow. No amount of turning the sketch black, making key points coincident with model geometry, will make down stream geometry change.
Well, that has been a couple years. But now I get to. The recent update which I have been putting off completely screwed Fusion up. All the "fixes" show you un installing from Fusion being open, but Fusion won't open. I can't uninstall it, because my computer says it isn't there.How long since you wiped Fusion off your computer and did a clean install? Same for the operating system? Just a thought.
I really wish we would add Fusion to the list of the machine tools that can't be mentioned here. It has been exhibited time and time again that they aren't "big boy caliber", falling more in line with the likes of the Atlas and Craftsman etc etc brands. I think it was back in December there were multiple posts weekly about problems with it. We pay big money for our CAD/CAM system like a business should do, the rest of the hobby level guys running Fusion on Centroid controllers can shoot over to the home shop site. I don't think there has been a strictly positive thread about Fusion here.
I was going to say < format c: > works good but these days, the reinstall is probably a bitch ! Ah owe mah soul to the company store ...I haven't the foggiest how to wipe the operating system and reinstall. How do you do that? I have no way to reinstall it?
Notice
