rhoward
- Apr 10, 2003
- Everett, WA, USA
I just bought a well used Ford F450 Super Duty flatbed with a 460 engine. I know the motor has a couple of burnt valves as when idling I it drops a cylinder or maybe two and on acceleration chugs up to speed. So I am certain the heads need to be rebuilt. The second issue is that it burns oil and smokes. I am hoping that this is because of loose valve guides and/or bad seals. But it could be rings and that worries me. Don't want to do a head job just to find the rings are shot. So here are the symptoms: on cold start-up no smoke, no smoke at idle, no smoke on acceleration, lots of blue smoke on decelleration as when going down a hill. If I give it even a tiny bit of throttle the smoke stops immediately and I mean immediately.
So what is the consensus? Heads, rings, both? Bty the engine has 137K miles on it and runs fine other wise. No weird noises, no overheating, good oil pressure.
Randy
Randy
