Who makes a good ER collet with low runout? REGO-FIX? Techniks? Or do you guys have good success with the Maritool collets?
I had a job running great- incredible tool life, good chip formation, good cycle time. I was happy. Then, the 5/16" solid carbide 3-flute end mill that I'm slotting with snapped about 1/4" into the collet, destroying the collet. The tool honestly didn't even look that bad, but I had made 10k(!!!) parts with this end mill, so I guess I had found the limit of the tool. Now, with a new collet and the same type of end mills, I am getting chipping on 1 or 2 teeth of the end mill after a short time. I had bought a collet from YG-1, which I suspect is giving me runout problems. A gage pin tightened in the holder is giving me .001"-.003" runout about an inch from the collet face. So, I'd like to get a really good collet just to eliminate that as a problem in case I'm dealing with other issues here.
This is on a live tool lathe, so I have to stick with the ER20 collets that the holder uses. I checked my holder after the tool snapped, and it's fine- couple tenths runout and no slop in the bearings. The collet nut might be a problem as well. It's a two-piece nut, and the inner piece is stuck pretty good in the outer piece. It's acting like a one-piece nut. Does anyone have any tips on freeing those seized nuts? I took out the set screw in the side and was able to get one of the balls out, but the others aren't coming. There are a lot of fine chips in there.
I'm not using a torque wrench to tighten the collet nut. Should I be using one?
