I'm having problems with my z axis position on my speedio s700x1. I have not made a part on it yet.
I set a haimer probe on my speedio in T20.
I set the tool length offset for T20 to 5.2XXX" (in data bank --> 2. Tool Data --> 1. Tool List --> T20 Tool Length Offset )
I jogged the spindle w/ T20 loaded such that the Haimer zero'd out.
I set the work offset with the spindle in the haimer position above. (data bank --> 1. Workpiece coordinate zero --> G54 --> automatic setting w/ 0.000 adjustment for x, y, z).
I switch to my T4 with tool length offset to 3.7XXX" using the ATC buttons and rotate L/R.
I jog to my absolute position from above.
I see the tip of the endmill is about 1.5XXX" above my G54 position.
I was expecting the speedio to compensate for the different tool height when I changed tools, but it did not do this in manual mode. Is this normal? Am I doing it wrong?
I tried to cut a simple part. The CAM program uses a G43 H04 for tool height offsetting the T4 from above.
When the speedio goes to make the first operation, the endmill is about 5.2XXX" above the G54 position.
What am I doing wrong?
Thanks for any help.
