SteeCityEngineer
- Apr 1, 2022
Has anybody any experience/suggestions of how the above may be achieved?
The bearing in question is a 420mm OF spherical roller and the housing which is worn slightly oval is formed between 2 halves of a very large and irreplaceable gearbox case. For similar repairs in the past on non-split housings have simply over-bored and shrunk in a EN19 (4140) sleeve with a decent wall thickness then finish bored back to desired size. However I am not sure how best to do similar with a split type housing.
I have considered but am nervous about weld recovery of the bore this is probably not desirable as the material is cast iron although obviously could be done with suitable electrodes, I would also worry about any possible distortion or similar through heat input. Are there any other options for this type of repair that others may have done before?
