I can't believe that you only had 1 gallon of Vactra! That's like buying beer 1 can at a time.
John,
I hate to disagree with you, but Peritack was the tackifier that was removed from Vactra in the 1990's because it was not compatible with synthetic coolants. Everybody else removed it too, but Vactra is what is known here. Mobil developed other tacifiers and today's formulation is IMO just as good as the old stuff.
I hate when these threads get started, because there is some much bad information that gets put out there. Just because your buddies, friends, brother-in-law did it, doesn't make it right.
1. Unless it's 20 weight (not 20W) non-detergent motor oil, don't put it on a machine tool. Most automotive lubrication products have chlorinated esters, and sulfides to provide the EP designation. These are the items that are not friendly to copper alloys. Detergent motor oils will reek havoc on machine tool oiling systems.
2. Chain bar oil is as cheap as it gets. Stihl and Takasawa (IIRC) used to sell oil with a tackifier, but their formulation has changed in the last few years. I run used motor oil in my chainsaw, the trees don't know the difference.
3. If you want a substitute oil or something for odds and ends oiling, go to the big box store and get a quart of air compressor oil. It's usually about a 20 weight (ISO-46) with no detergents or additives.
Just my $0.02 lunch is over
JR
