dannyrocci
- Mar 25, 2010
- Vancouver Wa
So I've been on the look out for a lever collet closer for sometime now and final found one. It came today and looks great the only problem is it doesn't seem to fit. As you can see in the picture the closer, I believe should fit in side the gear but it is not small enough to fit. This was suppose to be a plug and play sort of thing but of course it can never be that easy.
So do I have the gear on my machine wrong? I was always under the impression that I had the right gear for a lever collet closer.
I know that there are two version of the lever collet closer for the heavy 10 and I believe this is the later model. Do the two model take different gears?
The inside diameter of my gear is 1.436" and the outside diameter of the collet closer is 1.751"
Thanks for the help guys.
